+ Reply to Thread
Page 2 of 7 FirstFirst 123456 ... LastLast
Results 26 to 50 of 151
Thread: OScam: Exemple de configurare
  1. #26
    Happy® fery21's Avatar
    Post Thanks / Like
    pai verifica caid 0B00 nu e corec 0b02 seteaza cardu corect si merge
    nu ai acel caid in reader pune log la card
    FREE ALIEN
  2. #27
    Standard RSP member Special Member
    04 Jan 2010
    Post Thanks / Like
    Ok am ramas pe 0b02 si se pare ca numai history vrea sa-l deschida cu 0b02 restul cere 0b00.am si upc cinema dar :
    2011/04/03 23:32:49 3DF334E8 c dvbapi (1815&000000/78C2/92:8FD4): rejected group (1 ms) (of 0 avail 0) (no matching reader)
    2011/04/03 23:32:49 3DF334E8 c dvbapi: try pids again #1
    2011/04/03 23:32:49 3DF334E8 c dvbapi (0D02&0000A0/78C2/84:933C): rejected group (0 ms) (of 0 avail 0) (no matching reader)
    2011/04/03 23:32:49 3DF334E8 c dvbapi (0B02&000000/78C2/4C:598B): not found (10 ms) by localreader (of 1 avail 1)
    2011/04/03 23:32:49 3DF334E8 c dvbapi (1815&000000/78C2/922FF): rejected group (0 ms) (of 0 avail 0) (no matching reader)
    2011/04/03 23:32:49 3DF334E8 c dvbapi: try pids again #2
    2011/04/03 23:32:49 3DF334E8 c dvbapi (0D02&0000A0/78C2/84:58C2): rejected group (0 ms) (of 0 avail 0) (no matching reader)
    Pe asta il deschide 2-3 minute dupa care ecran negru ...
    2-3 cutii cu linucsi hw:mips si sh4;sw: openwrt si tidegloE2
  3. #28
    04 Jan 2010
    Post Thanks / Like
    Pe history deschide cu 0b02 iar pe discov Science cere 0b00 dar cardul nu e 0b00 ci 0b02 .Ce pot sa-i fac ?
    Pe cinema acum deschide corect
    La ce frecv tineti voi cardul de focu ca la 3.57 am ecm de 180-200 iar la 5-6mhz am 140-150 ms
  4. #29
    Post Thanks / Like
    4,8 si ecm time de 140 insa ce mi sa spus si mie daca il pui in oscam nu prea mai conteaza lucru asta,daca il pun in cccam cu 4,8 am ecm de 220
  5. #30
    Post Thanks / Like
    Eu iti recomand sa pui si la reader si la user
    caid = 0b02
    ident = 0b02:000000
    Experienta este cel mai dur profesor, pentru ca intai iti da testul si apoi iti spune care era lectia. - Vernon Law
  6. #31
    04 Jan 2010
    Post Thanks / Like
    [reader]
    label = localreader
    enable = 1
    protocol = internal
    device = /dev/sci0
    services = focus-familia,focus-aventura,focus-cinema
    caid = 0B02
    detect = cd
    mhz = 500
    cardmhz = 357
    ident = 0B02:000000
    group = 1
    emmcache = 1,3,2
    lb_weight = 100
    asa am pus
  7. #32
    Post Thanks / Like
    Renunta deocamdata la services pina merge si incearca sa dai o linie N in alta scula.
    Cererea e proasta cred, nu cardul. Asa mi-a aparut si mie azi, imi veneau ca cereri niste balarii dintr-o anumita directia, dar in rest totul era bine, alte cereri erau normale.
  8. #33
    04 Jan 2010
    Post Thanks / Like
    Am bagat si fara services si la fel cere pe 0b00 si ecran negru
    Pai in services am asa:
    [focus-aventura]
    CAID=0b02
    provid=000000
    srvid=03f6,03f7,03f8,785e,77f7,77ee,7853,77f6,78bb
    Am sa incerc si cu un N
    Am facut niste teste si iese ceva interesant :
    cu 3.57mhz ecm de 200ms
    cu 4.8 ecm de 110
    cu 5.0 ecm de 180
    cu 6.0 ecm de 140
    ---------- Post added at 23:29 ---------- Previous post was at 22:08 ----------
    Am aflat de ce tragea din 0b00 pentru ca eram pe 11862 mhz care e 0b00 .am dat pe frecv upcro si deschide cu 0b02.
    Scuzele mele
  9. #34
    Standard RSP member Member dodo13's Avatar
    19 Nov 2009
    Post Thanks / Like
    Default cardul focus pe cccam/oscam
    am incercat toate configurile din tutoriale. Cardul il vede ok dar la decode intra pe network !
    useri din newcamd sint conectati, serverele din ccam conectate dar nimeni nu ia nimic de pe cardul meu. O porcarie de emu..............Am urmat pas cu pas toate configurarile atat romani cat si straine .Acelasi lucru cardul ok si decode ioc.
  10. #35
    04 Jan 2010
    Post Thanks / Like
    pai de ce altora le merge ?
    posteaza fisierele tale sa vedem unde gresesti
  11. #36
    29 Mar 2007
    Post Thanks / Like
    Draga Dodo,
    ca incerci este bine , ca te enervezi nu prea este bine. Problema ta pleca din lipsa citiri cu atentie a documentatie, acolo ai fi gasit ca poti face anumite prioritati, si asta e cu 2 variante ( http://streamboard.de.vu/wiki/index.php/OSCam/en/Config/oscam.conf#preferlocalcards , http://streamboard.de.vu/wiki/index.php/OSCam/en/Config/oscam.server#lb_weight ) asta pentru cardul tau. Faptul ca intra pe retea poate spune multe, lista e destul de mare dar deobicei pozitionarea Readerului in nici-un grup sau intr-un alt grup decat cel al userului de decodare duce la ocoloriea localului. Plimbate un pic pe afara respira aer curat si revino la computer cu o mai mare atentie si o dorinta de a afla mai multe despre oscam.
    O seara placuta.
  12. #37
    RSP Team zmeura's Avatar
    08 Apr 2007
    Post Thanks / Like
    Vezi si ce ai pus la ident,doar ca asa ne putem da noi cu parerea degeaba.Vezi unde iti genereaza log-ul sau da un restart din webif si copiaza de acolo ce se intampla,altfel ghicim ca Mama Omida pe aici.
    Nu folosiţi oscam în locul cccam!
    Dacă e neapărată folosirea lui, cel puţin nu îngrăşaţi payserverele cu schimburi de cache!
  13. #38
    RSP Enigma Team Bust3D's Avatar
    02 Feb 2007
    Oradea
    Post Thanks / Like
    @Tehnomate,
    La fiecare reader are un group
    group=1
    daca ai mai multe readere readerul celalalt sa fie
    group=2
    si asa maideparte daca ai mai multe readere.
    iara, la fiecare user trebuie specificat group caruia vrei sa apartina, sa stie la care reader sa faca requesturile.
    Un fel de asociere user cu reader
    deaia iti da errorile alea...
    Daca corectezi astea o sa-ti mearga
    Bafta.
  14. #39
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    Post Thanks / Like
    ca si completare:
    multi am vazut ca pun la readere multi id-uri (ex=1,2,3..)ce este total gresit, fiecare reader sau grupuri de readere(cccam) se pun pe un identificator unic ca si protocol, doar la useri se aloca multi acces: group= 1,2,3....n
    readerele locale se pun pe grupuri diferite, readerele din protocol newcamd se pun si ele in continuare pe grupuri separate, readerele cccam se pun in urmatorul grup(local+newcamd...) si se pot atribui tuturor un singur id, in cazul in care dorim o interpretare separata a unei linii C fata de restul ii atribuim un alt id( o linie C preferentiala la care nu dorim expedierea ei in afara de dvbapi sau user x).
    ex:
    R_local1=grup1
    R_local2=grup2
    R_newcamd_1=grup3
    R_newcamd_2=grup4
    R_cccam_1=grup5
    R_cccam_2=grup5
    R_cccam_n=grup5
    R_cccam_n+1=grup6
    userdvbapi=1,2,3,4,5,6 #acces la toate readerele
    user1=grup1,2,3,4,5 #NU are acces la reader 6
    user2=grup6 #acces doar la reader 6
    user3=grup2 #expediere local 2 in newcamd.....
    o setare gresita grup reader/user-services dau si acele erori "no matching reader" " invalid sid".... la readerele C nu se atribuie services decat daca se cunosc exact pachetele(!!!!)-sau se creeaza o limitare voita-eu unul nu am testat, deci nici nu stiu daca lucreaza services pe protocolul cccam.
    Azbox HD with OpenRSi 3.0 powered by OSCam
    DVB-S DVB-T Triax TDS110
  15. #40
    19 Nov 2009
    Post Thanks / Like
    Default asta este una din configuratii
    [global]
    serverip = 192.168.0.22
    logfile = stdout
    cwlogdir = 0
    disablelog = 0
    disableuserfile = 1
    usrfileflag = 0
    clienttimeout = 5000
    fallbacktimeout = 2000
    clientmaxidle = 120
    cachedelay = 0
    bindwait = 120
    netprio = 0
    resolvedelay = 30
    unlockparental = 0
    nice = -5
    serialreadertimeout = 1500
    maxlogsize = 10
    waitforcards = 1
    preferlocalcards = 1
    [monitor]
    port = 999
    nocrypt = 192.168.0.0-192.168.255.255
    aulow = 30
    hideclient_to = 0
    monlevel = 2
    [newcamd]
    port = 34000@0b02:000000
    k_ey = 0102030405060708091011121314
    allowed = 127.0.0.1,192.168.0.0-192.168.255.255
    keepalive = 1
    [dvbapi]
    enabled = 0
    au = 1
    boxtype = ipbox
    user =
    [webif]
    httpport = 9999
    httpuser =
    httppwd =
    httpcss = /var/***s/blue.css
    httptpl =
    httpscript =
    httprefresh = 10
    httpallowed = 192.168.0.0-192.168.255.255
    httpdyndns = xxxxxx.DYNDNS.ORG
    httphideidleclients = 0
    httpreadonly = 0
    [anticasc]
    enabled = 0
    numusers = 0
    sampletime = 2
    samples = 10
    penalty = 0
    aclogfile = ./oscam_ac.log
    denysamples = 8
    fakedelay = 1000
    [cccam]
    port = 12000
    version = 2.0.11
    build = 2892
    reshare = 2
    stealth = 1
    minimizecards = 1
    updateinterval = 0
    keepconnected = 0
    [reader]
    label = Ipbox 200s
    protocol = internal
    detect = CD
    device = /dev/sci0
    group = 1
    caid = 0B02
    ident = 0B02:000000
    group = 1
    emmcache = 1,3,2
    blockemm-u = 1
    blockemm-s = 0
    blockemm-g = 1
    blockemm-unknown = 1
    services = Focussat
    # remote newcamd 1
    [reader]
    label = remote1
    protocol = newcamd
    device = 192.168.0.22,34000
    user = user1
    password = password1
    group = 1
    fallback = 1
    # remote CCcam reader
    [reader]
    label = remote2
    protocol = cccam
    device = 192.168.0.22,12000
    user = user4
    password = password4
    group = 2
    caid = 0b02
    cccversion = 2.0.11
    cccbuild = 2892
    Nu vrea sa mearga..........
    ---------- Post added at 07:42 ---------- Previous post was at 06:11 ----------
    am pus in bin un oscam ......nu stiu ce ver. dar are 380 kb. Acum merge cardul pe local dar nu merge web info. cu ver. 99 sau 1.00 merge web info dar intra pe network si nu merge cardul
  16. #41
    08 Apr 2007
    Post Thanks / Like
    Fisierele de configurare trebuie sa fie in var/tuxbox/config.
  17. #42
    Tok'ra Team stargate's Avatar
    23 Apr 2007
    P3X-888
    Post Thanks / Like
    Quote Originally Posted by dodo13 View Post
    am pus in bin un oscam ......nu stiu ce ver. dar are 380 kb. Acum merge cardul pe local dar nu merge web info. cu ver. 99 sau 1.00 merge web info :
    vezi ca sunt versiuni cu webinterface si fara webinterface ... un pic de atentie cand descarci
    Discutiile purtate si fisierele disponibile aici sunt în scop experimental si educational !
  18. #43
    19 Nov 2009
    Post Thanks / Like
    Default oscam
    versiunile sint mai multe dar cu unele merge localul si cu altele nu mai merge in conditiile in care setarile raman aceleasi, schimb numai versiunea de oscam din bin....concluzia este ca setarile de la o versiune nu sunt identice cu alta .....................asta in conditile in care am testat peste 5 versiuni de oscam si nici una nu a functionat cum trebuie. Setarile le-am facut conform tutorialelor de pe forum..................ma intoc la vechiul Sbox+cccam.
  19. #44
    08 Apr 2007
    Post Thanks / Like
    Eu stiu ca in versiunile noi trebuie sa :
    ....... fie in var/tuxbox/config.
    si nu in var/keys.Normal ca nu merge de pe local daca oscam nu gaseste fisierele de configurare unde e facuta si linia pentru cccam.
    Ai mai scris ca, "cardul il vede ok dar ..." dar nu ne-ai pus aici un log ca sa vedem si noi.In plus nici nu mi-ai raspuns la ce am scris mai sus,daca ai fisierele de configurare unde am zis si doar apoi sa testezi versiuni mai sus de 0.99 .
  20. #45
    19 Nov 2009
    Post Thanks / Like
    Default oscam
    fisierele de config erau puse conform tutorialului in var/tuxbox/config fisierele : oscam.server, oscam.user, oscam.config, cardul in web inf aparea ca ok dar nimeni nu primea linie iar mie imi intra pe network la decode.
    In versiunea mai veche luata de pe un tutorial de sky it cardul functiona local cu aceleasi setari dar clienti nu primeau linie de la mine, cu toate ca in oscam.user erau config. clienti si apareau off toti. Am incercat cu varianta de a face o singura linie pe care sa o testez in diferite grupuri..........care linie .............ca nu trimite nimic in share. Receptorul merge in local si atat. Clientii pauza totala .
    La versiuni mai noi cardul nici nu are bunavointa de a porni pe local, si ca de obicei clienti ioc.
    in web info cu acelesi setari cardul apare ok si ecran negru.............de clienti nu mai vb.
    Este unul din cele mai dificile emu intalnite .................ma lipsesc. Am incercat 2 zile ....mia ajuns
    ---------- Post added at 22:23 ---------- Previous post was at 22:13 ----------
    Quote Originally Posted by malin View Post
    Draga Dodo,
    ca incerci este bine , ca te enervezi nu prea este bine. Problema ta pleca din lipsa citiri cu atentie a documentatie, acolo ai fi gasit ca poti face anumite prioritati, si asta e cu 2 variante ( http://streamboard.gmc.to/wiki/index...eferlocalcards , http://streamboard.gmc.to/wiki/index...rver#lb_weight ) asta pentru cardul tau. Faptul ca intra pe retea poate spune multe, lista e destul de mare dar deobicei pozitionarea Readerului in nici-un grup sau intr-un alt grup decat cel al userului de decodare duce la ocoloriea localului. Plimbate un pic pe afara respira aer curat si revino la computer cu o mai mare atentie si o dorinta de a afla mai multe despre oscam.
    O seara placuta.
    am mai pierdut 2 ore degeaba sa citesc tot ...............mersi de bunavointa.Am facut ce m-ai sfatuit........m-am plimbat, am intrat in casa si am instalat din nou vechea configuratie.
    (Un tutorial mai sinplu nu gaseai?La ce este acolo si un expert are batai de cap.)
    O zi buna tuturor
  21. #46
    26 Oct 2009
    Walachia / Paname
    Post Thanks / Like
    o porcarie de emu e atunci cand epuizezi absolut tot si nu da randament, ca nu sti sa-l configurezi e alta mancare de peste. daca acel config e cel real .... e porcaria ta doar.
    de exemplu din setarile tale vad ca nici macar nu ai activat dvbapi, client pentru el nici atat, cine decodeaza, alt emu?
    services = Focussat merg pe mana ta si cred ca e ceea ce trebuie in el!
    localul e pe acelasi grup cu cel newcamd...care vad ca l-ai trecut si in fallback de ce, si din cate vad tu trimiti N tu te conectezi la el vezi reader N, CCcam la fel vezi reader C, ?!!!!!!
    asta in mare din ce vad, D-zeu stie ce alocari ai si prin acount-uri.
    cu o versiune mai la zi, incearca sa refaci formatele tuturor fisierelor prin "save" la fiecare, oscam.conf, oscam.server si oscam.user si asta prin webif, dupa care refaci fiecare sectiune, dupa ce o sa intelegi un minim din fiecare parametru ce trebuie setat atunci poti sa-l si configurezi, deabia dupa asta spui daca e bun sau e porcarie.
    spor la teste!
  22. #47
    18 Apr 2010
    Post Thanks / Like
    Default Req Help: Oscam & IpBox 900HD
    Am o problema ce ma intriga de ceva vreme si la care nu am gasit inca rezolvare.
    Pe IpBox 900HD am instalat Oscamul (updatat mereu la ultima versiune), iar ca imagine E2 de la AAF (ultima - Media Center Spring Edition) imagine care mi se pare cea mai buna ca stabilitate, dar intampin o problema cu Oscamul, problema ce apare indiferent de imaginea utilizata, la un anumit interval de timp canalul urmarit ingheata si in webinterface apare mesajul "no matching reader". Rezolvarea e simpla, schimb pe alt canal si dupa aceea pe canalul urmarit anterior si isi revine pana la proxima ocazie cand ingheata din nou si operatiunea de schimbare canal trebuie reluata.
    Este totusi suparator acest fenomen, mai ales cand urmaresti un film sau emisiune si o data sau de doua ori apare aceasta manifestare.
    Ce se poate face pentru a scapa de acest inconvenient?
    Vreau sa specific ca IpBox'ul il folosesc doar pe post de client, nu server si nu am nici un card pe el.
    Mai jos e cum arata: oscam.conf, oscam.server si oscam.user.
    Restul fisierelor: oscam.dvbapi, oscam.provid, oscam.services, oscam.srvid, sunt goale, nu am trecut nimic in ele.
    Ce as putea optimiza ca sa nu se mai blocheze?
    Multumesc in avans.
    ### oscam.conf ###
    [global]
    LogFile = stdout
    #LogFile = /var/swap/keys/oscam.log
    #usrfile = /var/swap/keys/oscam_usr.log
    ClientTimeout = 5000
    FallbackTimeout = 2500
    ClientMaxIdle= 120
    CacheDelay = 160
    BindWait = 120
    Nice = -10
    WaitForCards = 0
    #PreferLocalCards = 1
    saveinithistory = 1
    readerrestartseconds = 5
    lb_mode = 3
    lb_save = 200
    lb_savepath = /var/swap/keys/oscam.stat
    [monitor]
    nocrypt = 127.0.0.1,192.168.0.0-192.168.255.255
    appendchaninfo = 1
    [webif]
    httpport = 8888
    httpuser = user
    httppwd = pass
    httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
    [dvbapi]
    enabled = 1
    au = 1
    boxtype = ufs910
    user = dvbapi
    ### oscam.server ###
    [reader]
    enable = 1
    label = servercccam
    protocol = cccam
    device = 192.168.x.x,12000
    user = user
    password = parola
    group = 1
    emmcache = 1,1,2
    cccmaxhop = 4
    ### oscam.user ###
    [account]
    user = dvbapi
    pwd = dvbapi
    group = 1
    au = 1
    uniq = 0
  23. #48
    04 Jan 2010
    Post Thanks / Like
    In primul rand vad lb_mode si lb_save ca fiind o problema,ar fi bine sa pui lb_mode=1 .apoi vad ca iei si din hop4 .limiteaza tottusi macar pana la hop3.
    Uite cum imi merge mie foarte bine :
    http://sateliti.info/showthread.php?...l=1#post163605
  24. #49
    Standard RSP member parpaneata's Avatar
    09 Feb 2008
    Targu Jiu
    Post Thanks / Like
    Parerea mea este sa folosesti o varianta de oscam mai veche. Cred ca se insista prea mult in versiunile noi pe "floricele" webif care au marit oscamul si l-au ingreunat...."floricelele" mancand resurse bune. Am niste manifestari extrem de bizare pe ultimile versiuni....care m-au facut sa le testez din ce in ce mai rar.
    DM 800 HD,Optibox 550,Amiko shd 8000,plasma Samsung ps42d51sx/xec, lcd 3D Samsung le40c750,ochelari 3D SSG-2100AB.
  25. #50
    18 Apr 2010
    Post Thanks / Like
    .. am mereu ultima versiune de Oscam ce apare, comportamentul e acelasi.
    Am sa incerc si modificarile propuse de technomate sa vad daca se schimba ceva.
    Ce e interesant ca in paralel merg si cu vizcam care nu se blocheaza deloc, dar in schimb nu dechide anumite pachete, deci ma gandesc ca din setarile oscamului trebuie sa fie ceva.
    Multumesc de sfaturi, am sa revin cu feedback.
+ Reply to Thread
