Cum si unde se instaleaza oscam![]()
Deschid acest topic pentru cei care sunt interesati de SKi lT si au cardul de SKl in local!
OSCAM este cardserver ca si Newcs
Aveti atasata arhiva cu executabilul pentru:
i686 / sh4 / ppc / mipsel
Exemple de config :
Acum sa trecem la teste!Code:.conf [global] nice = -1 WaitForCards = 1 [monitor] port = 988 aulow = 120 monlevel = 0 [newcamd] key = 0102030405060708091011121314 port = 34000@093b:000000 .server [reader] Label = SkyItalia Protocol = Intern Detect = CD Device = /dev/sci0 group = 1 CAID = 093b BoxID = ###### #savenano = all Customspeed = 0 EMMCache = 1,3,2 Fallback = 0 #blockua = 0 #blockga = 0 #blocksa = 0 #AU = 1 #Enable = 1 .user [account] user = user pwd = pass group = 1 uniq = 1 caid = 093b ident = 093b:000000 AU = SkyItalia monlevel = 0
'' example how to config for sky it working on Dreambox
Put the bin in /var/bin (e1) or usr/bin (e2) atributes 755
Put the 3 files:
oscam.conf
oscam.user
oscam.server
in /var/tuxbox/config (e1) or etc/tuxbox/config (e2)
oscam.conf
[global]
nice = -1
WaitForCards = 1
[monitor]
port = 988
aulow = 120
monlevel = 0
[newcamd]
oscam.server
[reader]
Label = SkyItalia
Protocol = Intern
Detect = CD
Device = /dev/sci0
group = 1
CAID = 093b
BoxID = ###### (your BoxID)
#savenano = all
Customspeed = 0
EMMCache = 1,3,2
Fallback = 0
#blockua = 0
#blockga = 0
#blocksa = 0
#AU = 1
#Enable = 1
oscam.user
[account]
user = user
pwd = pass
group = 1
uniq = 1
caid = 093b
ident = 093b:000000
AU = SkyItalia
monlevel = 0
CCcam.cfg
N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256 ''
download :
http://rapidshare.de/files/48711895/...talia.rar.html
*preluat de pe un forum ( eu nu am testat , nu am la indemana dm ul ..... sorry )
Merge perfect, puneti la toate cardurile de SKl asa ca sa nu mai vina fake din cartile puse normal.
OSCAM este ce era NEWCS!
IN CCCAM sau MBOX puneti linii de newcs, la cccam cu 256 dupa!
How to start OScam from telnet
'' Thx to CCCam Team.
login into your box with telnet
call the directory by typing the below command and press enter
cd /var/bin
use the command to list all the files in the directory
ls
after this a list of files should be listed
look closely at the filename of oscam
and type the following replacing filename.ext with the one you see in the list
./filename.ext &
depends what you have in the config files you may see the debug on screen or just nothing happens on screen
you can open another telnet session in case needed and type the following command to confirm that oscam is running, if it is running you should see in the list filename.ext (depends on the oscam name)
ps -A . ''
cer scuze ,si rog pe cei ce au instalat acest OSCAM
in dream sa spuna mai exsact unde trebuie instalat
si cum.
am dream 7020si ,,gemeni.
va salut.
Acest emu este util/necesar numai celor ce au card Sky it!
cred ca acest emu va deveni ceea ce a fost pana acum newcs, poate chiar mai mult. sa speram ca va ramane open...
oscam-0.99.4.522svn-ppc-tuxbox-linux-dbox2-win
Mama m........ de roman , toti se dau "zmei" pe aici da nici unul nu explica si pt. cei mai neinitiati
Dupa ce a-ti descarcat/dezarhivat "oscam_r519 sky it" , veti avea in acest folder 6 fisiere , si-le copiati cu dcc -ul pt. e1 ( e2 inca nu am incercat ) :
- oscam.config
- oscam.server
- oscam.user
Toate 3 copiate in var/tubox/config cu atribut 755
- oscam_r519.ppc
Copiat in var/bin cu atribut 755
Apoi va duceti si editati fisierul "oscam.user" tot din dcc :
oscam.user
[account]
user = user care-l folositi la linia N
pwd = pass care o folositi la linia N
group = 1
uniq = 1
caid = 093b
ident = 093b:000000
AU = SkyItalia
monlevel = 0
Acum tot cu dcc-ul va duceti la var/etc/cccam.config si copiati linia N:
- N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256 sau
- N: 127.0.0.1 34000 user pass 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D
- USER si PASS ( din linia N ) sant cele scrise in fisierul oscam.user
La sfarsit da-ti un restart la dm
ZILDAN EDIT: Acest soft este un CARD SERVER, daca nu aveti cardul in aparatul vostru nu aveti ce face cu softul !!!
oscam-0.99.4.523svn-i686-pc-linux
oscam-0.99.4.523svn-powerpc-tuxbox-linux
oscam-0.99.4.523svn-sh4-linux
oscam-0.99.4.523svn-mipsel-tuxbox-linux
@mario08
E adevarat ce zici tu dar o mica paranteza
Daca nu ai local karte de sky italia nu trebuie sa faci nimic trebuie doar sa astepti päna cänd parteneri tai de sharing instaleaza oscam
Merge fara nici un seting probat de mine la un Dm 800 & 8000 CCcam 2.1.1 & 2.1.3
Am probat la 8000 si cu karte si merge daca faci setingul box-id
E ceva de genul digi cartela + rec
Stati linistiti si asteptati päna partenerii de schimb cu local vor instala oscamul si veti putea viziona linistit ( daca nu i-ati sters )
NU INSTALATI NIMIC DACA NU AVETI KARTE SKY ITALIA
daca citesti tot thread-ul si nu doar ultimul post, iti dai seama clar ca e card server, si merg si alte carduri, nu e doar pentru Sky IT! Marele plus se pare ca poti filtra si in CCCam nu mai ai 3 CAID pentru TVR![]()
dm800hd, T90 39E-28E-23E-19E-16E-13E-9E-5E-1W , 37LH4000, Logitech Z-5500 Digital
Salut,am un 7020 si am facut exact asa cum a postat Mario(multam Mario) si nu se lumineaza nimic,mentionez ca am sky it.in local.Rog ajutor
Merge si pe kathrein cu cardul connax autohton in phoenix.Am incercat si cu cel nds, dar in continuare nu vrea in phoenix.
