Thanks Thanks:  45
Likes Likes:  7
Dislikes Dislikes:  2
Results 31 to 45 of 82
Thread: NeutroLuxHD (Experimental)
    01 Sep 2010
    Andromeda
    Fixed an error
    - New station list
    Added new logos -
    - To feed and samba, ntfs and lua after instalation
    - Fixed bug and added new Oscam t 40
    - To feed is openVPN with enable password
    Added youtube player and several more -
    - Added new Multics
    - New lua additionally installed by online update
    - Rass radio text - tv / radio button then e.g. Select SWR3
    - Sbox added (even without config)
    - New emu wicard (experimental!!) Can eg make funcard, cs357, conax cas 7 u.s.w.
    -New  (blue button) wWrowser-ne who has keyboard Bissel can play with it,  that's not chrome, firefox etc replacement - questions such as "how can I  surf, fav store etc., are currently useless
    - New emu t39 inflicted S02, V13 1a go unlock
    - I do not like nor really long time operation with emu, there goes best mgcamd, others by example 35 std. Raking it there once and reboot needed
    New point-movie browser - Analysis of TS files
    - In the VAR folder / tuxbox / config are two lists for a webtv-only German, one with all possible
    - Corrected for recording Oscam
    - Recording will play directly underneath the coil and the key is to work for me
    -Libplayerfix
    Fixed streams
    Fixed Stations -
    -Satelites.xml missing are still there at Astra 2 transponder incorrect
    - Plus screen test for the purpose off
    - Start / stop with video compelling
    - Extended EPG - Menu> OSD> List of Channel, only programs with MINI TV
    - Progress bar switchable
    - Blue Button Game
    - Blue button neutrino plugins, emu point
    - AdZap (ad zapper) is inside
    - Flex Menu integrated (NeutrinoHD plugins)
    - Movie Player GOTO function integrated
    - 3D modes Side-by-Side/Top-Bottom/Tiled
    - OSD setting possibilities on flood
    - Info Viewer displays the correct button names
    - Lautstaerkeanhebung / lowering is adjustable per channel audio
    - GraphLCD (the cheap LCD that there was at Pearl) is supported
    - HDMI CEC is integrated
    - Mount / unmount the drive menu
    - LED feedback when pressing the remote control
    - FreeSat and Viasat EPG is supported (also MHWEPG, via a batch job)
    - OSD display for PSI settings (color, contrast, ...)
    - Logos neutrino and E2 are supported Picon
    - Oscam calling IP: 8888 webif oscam
    - Ip webif
    - NTFS HDD can be described (but slow!)
    - FTP support, rights such as 755 can be set with any FTP program
    - WebTV
    - UPnP Browser
    - Commander TuxBox
    - Tuxwetter
    - New wireless drivers integrated
    - Multiple languages
    Download: Link 1 Link 2 Link 3
    Acoperire totala (C, Ka, Ku) 180 E - 177 W [ultima actualizare realizata astazi:10.07.2013]
    Se dezarhiveaza zip-ul cu numele update de la download si ceea ce rezulta se pune la var/tuxbox/config
    31 Dec 2008
    Pentru Alien2 exista o astfel de imagine?
    01 Sep 2010
    Andromeda
    @dark - Exista dar nu a cerut-o nimeni.
    14 Feb 2011
    Earth
    Cum fac update , fara sa pierd setarile existente ? Multumesc...
    01 Sep 2010
    Andromeda
    Link alternativ pentru a descarca ultima versiune Neutro Lux HD pentru Amiko Alien 2
    Download
    @pharma - In primul rand trebuie sa descarci o unealta. Prin intermediul acesteia poti edita: lista de sateliti, favorite, redenumesti canalele.
    Aplicatie NeutrinoLux HD: Link 1 Link 2
    Rulezi aplicatia si treci la setari. Intra la Configure si acolo setezi dupa caz: user+parola. De asemenea trebuie
    sa alegi la Settings Aztrino! Se da save dupa ce ai setat ce te interesa. Apoi apesi pe 'from Decoder' si alegi
    un loc anume unde sa salveze! Succes!
    01 Sep 2010
    Andromeda
    Daca atunci cand rulati aplicatia de mai sus va apare eroare din captura, trebuie sa instalati in calculator: Net framework 3.5
    01 Sep 2010
    Andromeda
    ======= NEW UPDATE =======
    =========== Amiko Alien 1 ==============
    01 Sep 2010
    Andromeda
    Va rog sa verificati care aveti motor daca va functioneaza. Eu nu am, ca atare: verificati, confirmati sau infirmati!
    Eu cred ca ar trebui sa fie in regula.
    17 Mar 2008
    Default amiko alien 1
    Aceste imagini sunt foarte in regula,functioneaza bine cu motor hh,scaneaza rapid transponderii si afiseaza
    timpul estimat la schimbarea satelitului;....mai sap.. oricum mii de multumiri pentru ceea ce faci! Spadolin
    Last edited by dMd; 09-08-13 at 17:06. Reason: R. 12- quote inutil la postari consecutive
    10 Jan 2011
    4 Post(s)
    Thumbs up neutroluxhd
    sal mane tu spui ca img de mai sus amintita merge pe h-h da?
    dar pe acuator cu poztioner v50 cel cu patru fire merge img astea daca are cineva sau a facut teste rog frumos sa vina sa spuna cum facem si noi care detinem img neutro hd mii de ms asteptam teste poze confi
    01 Sep 2010
    Andromeda
    Gratie lui Thomas avem acum si un editor de canale pentru aceasta imagine[editorul dogsettings a fost doar o alternativa]
    Vreau sa stiti ca imaginea evolueaza pe zi ce trece!
    02 Nov 2008
    sall.am un amiko alien 2 si nu reusesc sa configurez tunerul la imaginea asta.pe tunerul 1 am un diseq cu 4 iesiri si tuner2 la fel.cine se pricepe un pic de ajutor va rog!
    ---------- Post added at 14:22 ---------- Previous post was at 14:04 ----------
    testul de semnal este ok dar cand scanez nu merge
    02 Nov 2008
    este semnal dar nu merge
    E pe alt satelit antena!
    01 Sep 2010
    Andromeda
    @costy - Spune-mi mai exact ce sateliti ai pe acele iesiri? Satelit A,B,C,D! Asta daca nu cumva are dreptate maestrul @zildan si esti pe alt satelit (posibil pe 9 E)...
