Page 8 of 9 FirstFirst ... 456789 LastLast
Results 106 to 120 of 125
Thread: Imagini dreambox-clone!
  1. #106
    12 Aug 2007
    Default Re: Imagini dreambox-clone!
    Pentru dream 500 cu mac original , gemini project 431 cu au ptr mct .
    DOWNLOAD
  2. #107
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Default Offtopic
    @maximus....de la asta ti s-a tras. Nu te-ai cumintit??????
  3. #108
    12 Aug 2007
    Am specificat ca e numai ptr originale , clona mea a picat cu aceasta imagine , acum daca am mac de original (mac-ul apartine dream multimedia dupa verificare) sau asa cred ... inca nu m-am cumintit , ce o fi acum , se buleste sau nu .
  4. #109
    12 Aug 2007
    Am bagat fisierele ce fac au la mct si red light intr-o imagine gp 4.4 fara bomba si nu a mers , in imaginea gp 4.4 cu bomba a functionat perfect.
  5. #110
    Quote Originally Posted by maximuss View Post
    Pune la loc imaginea cu bomba,acum ca ai MAC de original nu are de ce sa iti fie frica.
  6. #111
    12 Aug 2007
    Cititi cu atentie cam ce face imaginea asta ...eu nu am reusit ...aveam varianta 1.1. Oare ce fac fisierele de pe rapid share ?
    http://www.digital-kaos.co.uk/forums...00-c-s-t-3872/
  7. #112
    poate nu ti-a mers fiindca ai luat o imagine pt. DM 500C (pt. cablu) nu de satelit , cel putin link-ul pus de tine deschide sectiunea DM 500C.
  8. #113
    12 Aug 2007
    Am specificat '' cititi cu atentie '' si tu doar ai citit , imaginea functioneaza pe dm500 s dar nu mi-a reusit faza din rapid share .
    Well it's been a long time coming but it's eventually here - Digital Kaos v1 image for all versions of DM500, cable satellite and terrestrial.
    Please read this post in full before asking any questions. All questions with answers in this post will be referred here.
    A few details about the image!
    Yellow - Kaos Panel (Extra settings, Manager suite, User features)
    Blue - Plugins (preloaded with a few)
    Red - EPG (double press to bring up a few options including EPG Search)
    Green - SubServices for satellite viewing, i.e. Premiere Sport Portal. Also if you hold it down for more than 3 secs it shows the DVR controls for reco***ng.
    Info - Infobar popup as usual but hold down for more than 3 secs to bring up the EMU Manager, kind of a hidden menu.
    Kaos Panel
    Kaos Extra Settings
    --Loads of extra settings in here, have a look and have a play
    --Enable picons (/var/etc/picon)(attached) These are icons that show the channel logo, takes up room in /var so it's disabled by default, can also be downloaded from the addons menu.
    Manager Suite
    --Addons Manager - Download plugins, emu, configs, etc
    --Slot Manager - For smarcards (sat)
    --Infobar adjust - Adjust the position on the infobar on your screen
    --Backup Manager - Backup your settings, plugins, skins, config, services, bouquets, etc. File will be generated in /tmp called backup.tar.gz.
    --EPG Manager - Not used on the DM500.
    --Audio Language Manager - Set priority languages for satellite users.
    --Var Move Manager - Move /var to the /hdd, or /usb devices, not used on the DM500.
    Addon Manager
    --Install Local Addon - copy file to /tmp and install using this option
    --Server: DK Addons - Internet addons available to download
    --Uninstall Addons - Uninstall any addons you have installed
    User Features
    --Flash Image - Copy img file to /tmp and rename to backup.img
    --ServicesBackup - Creates a services.tar.gz file in /tmp with all services and bouquets
    --ServicesRestore - Restores services.tar.gz if placed in /tmp
    --ReloadChannels - Reloads channels if services or bouquets have been manually altered
    --BackupImage - Creates a backup.img file in /tmp - this is a complete backup
    --PanicButton - Removes emu, keys, roms, services, bouquets, etc...everything to make it a FTA image. A factory reset or reflash is required if you select this option
    Included Plugins
    DreamNetCast Internet Radio - Listen to internet radio if your dreambox is connected to the internet. Add stations in the /var/etc/stations.xml file.
    RSS NewsReader - Read RSS feeds on your dreambox. Including the Digital Kaos forums. Edit the /var/tuxbox/config/rss/feeds.xml file with your own feeds, although some have been added for you.
    Tuxbox Commander - For editing the filesystem on your dreambox.
    Teletext - Available via the 'TEXT' button on remote or via the blue button menu.
    Internet Image Updates
    All future image releases will be available to update over the internet.
    Menu > Setup > Expert Setup > Software Update > Internet Update
    If you are currently using a DW image and you want to copy your services and bouquets to this image, do the following...
    Using remote, Blue > User Features > ServicesBackup
    FTP to your dreambox and navigate to /tmp.
    Copy the services.tar.gz file to your PC.
    Flash the new DK v1 image.
    Copy the services.tar.gx file from your PC to your dreambox.
    Using remote, Yellow > User Features > ServicesRestore
    Exit out all menus, hold 'INFO' to bring up the EMU manager and press OK to start
    DO NOT COPY YOUR WHOLE /var/tuxbox/config/enigma FOLDER TO THIS IMAGE!!!! IT WILL NOT WORK!!!!
    No Keys or Roms
    This image is supplied without any keys or roms. It is a FTA image only!
    But I did find that someone has uploaded these files which appear to work fine with this and any other image.
    RapidShare: Easy Filehosting
    Copy contents of Keys folder to /var/keys
    Copy contents of Scce folder to /var/scce
    Go to Sky Sports 1
    Hold INFO for more than 3 secs to bring up EMU manager, press OK.
    Wait.......
    Screenshots
    http://www.digital-kaos.co.uk/images/dk_info.png
    http://www.digital-kaos.co.uk/images/dk_panel.png
    http://www.digital-kaos.co.uk/images/dk_emu.png
    http://www.digital-kaos.co.uk/images/dk_addon.png
    http://www.digital-kaos.co.uk/images/dk_infobar.png
    Thank You
    Special thank you to all members of the Merlin Project Team, Nemesis Team and CLi Team. Also thanks to all beta testers, your input is very much appreciated.
    Este si varianta 1.1 dar nu mai are chestia cu rapidshare
  9. #114
    7 Post(s)
    asta e traducerea mai pe inteles
    Ei bine aceasta a fost o lungă perioadă de timp, dar care provin din urmă este aici - Digital Kaos v1 imagine pentru toate versiunile de DM500, cablu satelit si terestru.
    Vă rugăm să citiţi acest articol in intregime inainte de a cere orice fel de intrebări. Toate intrebările cu răspunsuri in acest articol vor fi menţionate aici.
    Cateva detalii despre imagine!
    Yellow - Panou de Kaos (extra setări, Manager de apartament, cu caracteristici de utilizator)
    Blue - Dop (preincărcate cu cateva)
    Red - EPG (dublu de presa pentru a aduce o serie de opţiuni, inclusiv Cauta EPG)
    Green - SubServices pentru vizualizare prin satelit, şi anume, Premiere Sport Portal. De asemenea, dacă vă ţineţi-l in jos pentru mai mult de 3 secunde-l arată DVR controale pentru reco *** ng.
    Info - Infobar pop-up, ca de obicei, dar ţineţi apăsată tasta pentru mai mult de 3 secunde pentru a ajunge la UEM Manager, un fel de meniu ascunse.
    Panou de Kaos
    Kaos Extra Settings
    -- Multe setări in plus, aici, să aruncăm o privire şi să aibă o piesă de teatru
    -- Activare picons (/ var / etc / picon) (se anexează) Acestea sunt icoane, care arată logo-ul pe canal, va ocupa camera in / var deci este dezactivată in mod implicit, poate fi de asemenea descarcat de la addons meniu.
    Manager Suite
    -- Addons - Director Descarca dop, UEM, configs, etc
    -- Slot Manager - Pentru smarcards (SAT)
    -- Infobar ajusta - Reglaţi poziţia pe infobar de pe ecran
    -- Backup Manager - Backup pentru setările, dop, piei, configurare, servicii, buchete, etc fişier va fi generată in / tmp, denumit backup.tar.gz.
    -- EPG Manager - nu au fost folosite pe DM500.
    -- Limba Engleza Audio Manager - Stabilirea prioritate de limbi pentru utilizatorii de satelit.
    -- Var Mutare - Director Mutare in / var la / hdd, sau / dispozitive USB, nu sunt utilizate de pe DM500.
    Addon Manager
    -- Instalare locale addon - pentru a copia fişierul / tmp şi instala utilizand această opţiune
    -- Server: Addons DK - Internet addons disponibile pentru a descărca
    -- Dezinstalare Addons - Dezinstalare orice addons pe care le-aţi instalat
    Utilizator Caracteristici
    -- Flash Image - Copiere img fişier in / tmp pentru a redenumi şi backup.img
    -- ServicesBackup - services.tar.gz Creeaza un fişier in / tmp, cu toate serviciile şi buchete
    -- ServicesRestore - Restaurează services.tar.gz dacă plasat in / tmp
    -- ReloadChannels - reincărca canale sau buchete de servicii, dacă au fost modificate manual
    -- BackupImage - creează un fişier in backup.img / tmp - aceasta este o copie de siguranţă completă
    -- PanicButton - Elimină UEM, chei, uri, servicii, buchete, etc .. totul pentru a face o imagine de zone de liber schimb. Un Factory Reset sau reflash este necesară dacă selectaţi această opţiune
    Plugin-uri incluse
    DreamNetCast Internet Radio - Asculta la radio, internet, dacă dreambox dvs. este conectat la internet. Adauga in statii / var / etc / stations.xml fişier.
    RSS newsreader - Citeste Feed-uri RSS de pe dreambox. Inclusiv Digital Kaos forumuri. Editaţi / var / tuxbox / config / RSS / feeds.xml fişierul dvs. cu feed-uri proprii, deşi unele au fost adăugate pentru tine.
    Tuxbox Comandor - pentru editarea de fişiere de pe dreambox.
    Teletext - Disponibil prin 'text' buton de pe telecomandă sau prin intermediul albastru butonul de meniu.
    Imagine Internet Updates
    Toate versiunile viitoare de imagine va fi disponibil pentru a actualiza pe internet.
    Meniu> Configurare> Expert Setup> Produse de plastic Update> Internet Actualizare
    Dacă acum folosiţi un DW si imagine pe care doriţi să le copiaţi dvs. de servicii şi buchete de a prezenta imaginea, faceţi următoarele ...
    Utilizarea la distanţă, Blue> User Features> ServicesBackup
    FTP, pentru a vă dreambox şi navigaţi in / tmp.
    Services.tar.gz Copiaţi fişierul pe PC.
    Flash DK v1 noua imagine.
    Copiaţi fişierul services.tar.gx de la PC-ul dvs. pentru a dreambox.
    Utilizarea la distanţă, galben> User Features> ServicesRestore
    Ieşiţi din toate meniurile, hold "INFO" pentru a ajunge la UEM manager şi apăsaţi OK pentru a incepe
    Nu copiaţi toata / var / tuxbox / config / enigma folder pentru această imagine!!!! El nu va funcţiona!!!!
    Nr Chei sau Roms
    Această imagine este furnizat, fără nici cheile sau uri. Acesta este doar o zonă de liber schimb imagine!
    Dar eu am afla că cineva a trimis aceste fişiere care apar la locul de muncă, cu amendă, precum şi orice alte această imagine.
    Rapidshare: Easy Filehosting
    Copiaţi conţinutul folder Chei de la / var / chei
    Copiaţi conţinutul folder pentru Scce / var / scce
    Du-te la Sky Sport 1
    Ţineţi INFO pentru mai mult de 3 secunde pentru a ajunge manager de UEM, apăsaţi OK.
    Stai .......
  10. #115
  11. #116
    Nabilosat Enigma1 DarkStar II - DM500
    Thanx a lot for this good image to Nabilo Team!
    What is new in this DarkStar II DM500 ?
    Updated CVS: 30 August 2008
    The image has been completely recoded based on the latest CVS
    Updated Skin by porto
    New DarkStar II skin customized by porto
    Enigma 1 Integrated 8 Days Sky IT EPG
    Download 8 days Sky IT EPG, and have it integrated to Enigma1
    EPG Event Search
    Select a single channel EPG, press 0, enter a keyword and search for your preferred events
    EPG Channels Selection
    Customize the list of EPG channels to download. We reccomend to restart Enigma upon completing the selection
    EPG Channels Update List
    Update the EPG channels list when there are changes
    Standby after reboot
    Your DM will automatically standby after an accidental reboot, such as after a powercut
    Scheduled Reboot
    Schedule an automatic daily reboot
    Main Function Keys
    Button 1xOK = Light Info OSD
    Button 2xOK = Extra Info OSD
    Button Blue = Nabilo Blue Panel
    Button 2xBlue = Nabilo Extra Settings
    Button Yellow = Nabilo Yellow Panel - Plugins List
    Button 2xYellow = Nabilo Yellow Panel - Addons Manager
    Button Red = Current Channel EPG
    Button 2xRed = Select Channel EPG or MultiEPG
    Features
    Addons
    Dedicated Addons Server
    Download and install additional packages from Nabilosat server
    Infobar/OSD
    Enigma1 Analogic Clock
    Channel Orbital Position
    Signal SNR, AGC, BER
    Infobar Picons
    Advanced EMU information
    Nabilo Panels features
    1) Blue Panel
    Extra Settings
    Inadyn
    Nabilo EPG Settings
    Nabilo OSD Preferences
    Nabilo Scheduler
    Mount Points
    System Info
    Dreambox
    Mount Points Info
    Process Info
    Memory Info
    Enigma Setup
    Bitstream
    Save
    Select/Start/Restart EMU
    2) Yellow Panel
    Forums
    Shoutbox
    Addons
    Scripts
    Addons Download Manager
    Manual Install Panel
    Addons Uninstall Panel
    Images Uninstall Panel
    Nabilosat Statistics
    Many thanks to the Beta Testers Team
    Black33, ^^Corrado^^, ^^Maximo II^^, greg, Matrix10, Porto, ^)0(^Nabilo^)0(^, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, frimmino, astemio, DeepDiver, lorenzo64, robyhummy.
    Credits
    Sky IT Epg fully integrated to Enigma 1 by the great MaxZ4
    downloand;
    http://www.filebox.ro/download.php?k...d3f51a8dd76dcd
  12. #117
    E vreo noutate fata de ce am postat mai sus?
  13. #118
    O zi frumoasa! Snow's Avatar
    Poate o fi Nabilosat DM500 DarkStar II OpenVPN
  14. #119
    Standard RSP member vardic's Avatar
    29 Apr 2008
    root
    Default Nabilosat Enigma1 DarkStar II - DM500 OpenVPN
    info: http://www.nabilosat.info/forum/showthread.php?t=56527
    download: link
    a probat cineva imaginea Nabilosat Enigma1 DarkStar II - DM500? ... mai intereseaza daca isi mentine subtitrarea.
  15. #120
    Gemini v4.5:
    Technical Infos:
    * Enigma of: 06.09.2008
    * GCC 3.4.4 Original CVS
    * Web Interface: 6.0.4-Expert
    * Busybox 1.01
    * Tuxtxt V1.104
    * CIFS 1.44
    Remotecontrol:
    * BLUE - Blue Panel (BP)
    * 2x BLUE - BP -> Extras/Settings
    * YELLOW - Quick-Button (can be configured via BP)
    * RED - EPG list for active channel
    * 2x RED - EPG style menu
    * GREEN - subservices
    Addons:
    * own Addon-Server via Internet
    * adding additional functions via internet from the Gemini-Server and install them automaticly
    * Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
    * Create your own Satellites.xml, which only contains the Satellites you realy need
    Camd:
    * Different Camd´s can be linked to channels/provider (Autocam)
    * Changeing the name and settings via own menu.
    * Creation of a 2nd socket (/tmp/cam1.socket)
    Daemon / Server / Clients:
    * Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
    * Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
    * added editor to configure the cron-daemon
    * Little Apache (HTTP-Server based on HTTPD)
    * Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
    * Inadyn (Daemon for different DYNDNS-Services)
    * Settings for syslogd
    * Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
    * Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
    * NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
    Infobar / OSD / Skin / Background-Pictures:
    * Position of the Infobar can be changed without editing the skin files
    * Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
    * Display of EMM, ECM or "Expertinfos" are switchable
    * Picon (displaying the Channel-Logo)
    * Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
    * Background picture can be turned off (Plasma - Fix)
    * Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
    * Changing Bootlogo via menu ( 7020 only)
    * Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
    * Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
    * Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
    Files / Devices
    * Support for CDROM/DVD no matter using IDE or USB
    * Random function for all kind of soundfiles
    * Backup function
    * 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
    * support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
    * Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
    * Functions for SWAP (virtual memory). Create, delete, size and location.
    EPG
    * additional functions (e.g. dishnetwork, cache, location)
    * search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
    * Infos of the recorded movies can be shown without starting the movie
    * refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
    * autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
    * Duration of current event in the programm overview ( Menu -> Info -> EPG)
    * general information about the EPG Data (BP -> Info-> EPG-Settings)
    * a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
    Extras:
    * Dreamnetcast (shoutcast-player) with Streamripper (direct reco***ng from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
    * RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
    * System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
    * Own scripts can be started via Blue Panel
    * Changing the reco***ng parameters (extra before- and after- reco***ng time, storage location and recover-function for your records)
    * change the settings for reco***ng (before Time, after-reco***ng time,, location and recover-function)
    * Create your own satellites.xml including only the satellites you really need.
    * Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
    * alarm-clock with volume offset playing own WAV-Files
    * Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
    * Support for DreamDVD no matter wether a DVD-Drive is available or not
    * New screenshot routines (have a look at the Webif)
    * eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
    * disable the TV - output while taking a reco***ng, streaming a movie and manually (usefull for boxes with very low lan-speed)
    * update system time via transponder or internet ( Protocol RFC868 )
    * eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
    * create password using the BP (BP -> Extras -> Pwassword)
    * rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
    * Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
    * Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
    Reco***ngs:
    * records into different folders ( the settings have to be done in the Timer-Menu)
    * LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
    New:
    * import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
    * Records can now be done in the new Eniga2 format (*meta files) or as usal as "reco***ngs.epl" (BP -> Extras -> Record)
    * Reorganised the BP main menu
    * addition information can now be found in Menu -> Information (new optical appearance)
    * Device-Manager for HDD / DVD / CF / USB
    * reactivated the Jukebox (special wish of a very nice User ). Please install as addon.
    * Drivers for USB-Cardreaders are now included in the Image but are not loaded!
    Fix + update:
    * Dreamnetcast (now you can use TV and Internetradio at the same time)
    * RSS-Reader
    * Weatherforecast (now with favourites management)
    * SWAP
    * User-Script
    * have a look in the CVS
    Interfaces WebIF:
    http://127.0.0.1/cgi-bin/GeminiInfo
    http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
    http://127.0.0.1/cgi-bin/InitCam
    http://127.0.0.1/cgi-bin/ResetCam
    http://127.0.0.1/cgi-bin/setKey?typ=STR&...test&val=blabla
    http://127.0.0.1/cgi-bin/getKey?typ=INT&...itedvb/int-test
    We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
    This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
    Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
    The use of this Image is on your own risk.
    Recommendation:
    If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
    if several processes running in background. We assume no liability for direct or indirect damage.
    Download via Database
    Thanks a lot and have fun
    Your Gemini-Team
