Results 1 to 12 of 12
Thread: New: Nabilosat DM500 BlueStar II Cccam Surprise Mo
    13 Feb 2007
    Earth
    Post New: Nabilosat DM500 BlueStar II Cccam Surprise Mo
    New: Nabilosat DM500 BlueStar II Cccam Surprise Mod Borsalino 16.07.09
    hi all
    New : my new modefecation image of
    Nabilosat DM500 BlueStar II Cccam surprise Mod Borsalino 16.07.09
    the new: emu Cccam_2.1.1 with the integration of the image
    New in this imege
    -new bootlogo hd
    -Emu: CCcam 2.1.1 inside (start with image..in blue panel withe volume button for the built-Emu )
    -please send Cccam.cfg in var/etc withe ftp
    -add Cccaminfo_v1.1 (new) delet old plugins in image (Yellow Button)
    -add nagrab recording in image
    -Changed the original skins withe the new skins rihanna Blue mx
    -delet old skins
    -Now you can change the form of a channel presntation withe button help
    -all longage ok
    -add option DVR withe help botton
    -big var naw 75% Free espace
    -font size add
    -Fast image to open channels with Cccam2.1.1
    -option pvr ok withe this modifecation image
    -send this image withe dreamup or falshwizare
    Here are some of the screenshote for this wonderful modifectione image of Nabilosat DM500 BlueStar II Cccam surprise
    liste Language in demarge
    the cccam 2.1.1 inside in image
    the big var withe cccam
    13 Feb 2007
    Earth
    Post Re: New: Nabilosat DM500 BlueStar II Cccam Surpris
    '' the new skins inside in image rihanna Blue mx
    menu rihanna
    download :
    http://www.4shared.com/file/11854050...no_160709.html
    dMd
    Guest
    Default Re: New: Nabilosat DM500 BlueStar II Cccam Surpris
    O imagine pe care o asteptam de mult timp, merita incercata, nu are blocaje, retine subtitrarea, rapiditate la butonare, spatiu mai mare in var, iar la info apare ca Nabilo Darkstar II ...
    Super Member lucrad's Avatar
    02 Aug 2007
    Abia astept s-o incerc, eu sunt pt Nabilo.
    Invatati,invatati si iar invatati !!!
    Standard RSP member satyca's Avatar
    03 Oct 2008
    Default nabilo bluestar2
    Este intradevar facuta pe scheletul darkstar se misca repede ,memoreaza subtitrari,dar nu se pot face setarile in limba romana.
    dMd
    Guest
    Se pare ca aceasta imagine a deranjat cam tare staful Forumului Nabilo, pentru ca tot ce a fost postat pe pagina lor de @borsalino in legatura cu aceasta imagine modificata a fost sters. Banuiesc ca totul reprezinta o palma data ignorantei celor din Nabilo Team de a scoate o versiune DARK II MaxVar, varianta ceruta insistent pe forum-ul lor de utilizatori. In situatia aceasta a fost si PLI, la care spatiul din var era mereu insuficient, insa au corectat totul in ultima perioada prin scoaterea in paralel atat a imaginilor Regular cat si MaxVar. Sper ca acesta sa fie un semnal de alarma, semnal de care Nabilo sa tina cont iar atunci cand fac imagini sa se apropie cat mai mult de cererile utilizatorului si nu de propriile ambitii pentru ca valoarea oricarei imagini este data de utilizator, degeaba o evalueaza producatorul daca userul o ignora.
    叛徒 daradici's Avatar
    12 Apr 2008
    覆盆子灌木
    Am incarcat imaginea, intr-adevar este extrem de stabila, nu uita setarile de subtitrare, se misca bine....
    ....dar e un Darkstar 2 reskinuit si cu logo-uri schimbate !!!
    Afirm asta pentru ca am folosit cateva luni Darkstar 2 si am fost foarte multumit de imagine, singurul lucru care m-a deranjeaza este spatiul mic in VAR, ca de altfel si la aceasta imagine.
    .....spatiul destinat VAR este 1792 kb ca la darkstar2. La Nabilo 0.8 sau GP sau alte imagini care sint Maxvar este de 2.8 MB.
    Deci pana la urma este vorba de un Darkstar2, cu mici ajustari nu o noua imagine.
    12 Apr 2008
    覆盆子灌木
    Interesant este ca (cel putin la mine !!!) la aceasta imagine n-am reusit sa instalez din download panel sub nici o forma un alt limbaj decat cele initiale.
    Am incercat romana si maghiara, desi i-mi arata ca s-au instalat cu succes la languages preferinces nu apare nici-una din acestea.
    O alta diferenta fata de Darkstar2 este ca vine cu cccam preinstalat.
    Cam asta ar fi, un Darkstar2 putin modificat....
    24 Jun 2009
    Hamburg
    am impresia ca imaginile care vin cu cccam preinstalat nu suporta sa skimbi versiunea de cccam, asa am patit eu la versiune de gemini 4.6 no bomb modificata de brosario
    aceasi problema cu limba am avuto si pe gemini. daca dau previu la instalaea de skinuri nu imi arata nimic. acelasi lucru se intampla si la imaginea asta?
    caut sa trec la alta imagine dupa gemini fiind oarecum incepator.
    puteti sa imi dati un sfat, ma gandeam la aceasta.
    24 Jun 2009
    Hamburg
    am instalat aceasta imagine de 2 saptamani, si sant multumit de ea.
    am card dolce si cu aceasta imagine , la reboot acesta porneste mult mai repede.
    am incercat sa downlodez ceva de adons dar nu am reusit spune ca sa instalat ar nu gasesc nimic , si nici daca ma uit cu dcc nu asesc ceva fisiere noi.-cred ca se pot instala doar manual
    in rest merge bine.
    cel mai mare avanaj e viteza cu care porneste dupa reboot.
    bafta
    09 Feb 2007
    Bucharest
    Am instalat si eu pentru prima data Nabilo folosind aceasta imagine!
    Toate bune si frumoase, INSA, are un MAAARE minus, dupa parerea mea, si anume LIPSA serviciului CROND !
    24 Jun 2009
    Hamburg
    am incercat sa introduc datele in interfata de inadyn si nu a salvat cea ce introduceam
    asa ca am editat inadyn.script.sh si am intordus toate informatiile necesare
    dar cand ma duc in interfata par toate informatiile dar nu reusesc sa il fac sa porneasca , dau restart dar statusu ramane stoped
    acesta e inceputu de script poate gasiti vreo eroare
    #!/bin/sh
    DAEMON=/sbin/inadyn
    NAME=inadyn
    DESC="InaDyn dynamic DNS Client"
    INADYN_ON=1
    INADYN_USERNAME= xxxx
    INADYN_PASSWORD= yyyy
    INADYN_ALIAS= xxxx.dyndns.tv
    UPDATE_PERIOD= 300000
    LOG_FILE_ON=1
    LOG_NAME=/var/log/inadyn.log
    DYN_SYSTEM_ON=1
    DYN_SYSTEM= dyndns@dyndns.tv
    test -f $DAEMON || exit 0
    set -e
    case "$1" in
    start)
    if [ $INADYN_ON -ne 0 ]; then
    ARGS="-u $INADYN_USERNAME -p $INADYN_PASSWORD -a $INADYN_ALIAS --update_period $UPDATE_PERIOD"
    if [ $LOG_FILE_ON = 1 ]; then
    ARGS="$ARGS --log_file $LOG_NAME"
    fi
    if [ $DYN_SYSTEM_ON -ne 0 ]; then
    ARGS="$ARGS --dyndns_system $DYN_SYSTEM"
    fi
    echo -n "starting $DESC: $NAME... "
    /sbin/inadyn $ARGS &
    echo "done."
    fi
    stop)
    echo -n "stopping $DESC: $NAME... "
    killall -9 inadyn
    echo "done."
    restart)
    echo "restarting $DESC: $NAME... "
    killall -9 inadyn
    sleep 5
    $0 start
    echo "done."
    echo "Usage: $0 {start|stop|restart}"
    exit 1
    esac
    exit 0
    inca un lucru- eu am nabilo dark star 2 poate e important
    poate sa ma ajute cineva?7
    poate rebuia sa intreb la sectiunea dedicata Dyndns,ICSdar cred ca aici sant oameni avizati care cunosc nabilo si.......
