Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Dm 100
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Dm 100
    Primele fotografie de la DM 100.Este de la un prieten grec.....Are software inchis fara linux,dar se aude ca o sa iese patch cu care o sa ia emu...ramune sa vedem!!
    DM100.rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Re: Dm 100
    "How to " pt upload firmware in DM 100.Este cu fotografie....
    http://rapidshare.com/files/14612571...ad_DM100_S.zip
    DM100 Loader / Channel Editor.
    http://rapidshare.com/files/14612678...erChEditor.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    01 Apr 2007
    Default Re: Dm 100
    Interfete Ethernet si USB ; Blindscan , daca integreaza in sw un modul de comunicare cccam atunci va fi un hit .
    02 Feb 2007
    Default Re: Dm 100
    cam greu il vad.Mai repede ceva newcamd vad..
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Default Re: Dm 100
    O poza la placa de baza clara se poate?
    Nu e linux? Costa in jur de 120-130 euro.
    02 Feb 2007
    Default Re: Dm 100
    @gabitzu
    DM 100 nu e la mine acasa dar la un prieten care a luat-o ca beta tester.Nici o el stia care o sa fie pretul exact.O sa incerc pt poza dar e depinde de mine.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    05 Jun 2008
    Default Re: Dm 100
    la cati bani dai pe asta iti cumperi o clona cu linux
    01 Apr 2007
    Default Re: Dm 100
    ccamul este strins legat de dreammultimedia , de fapt merge doar pe enigma .
    pot sa foloseasca un emu particular care sa faca AU la anumite pakete ( tactica Duolabs cu Diablo v2.3 ) si atunci o sa fie foarte atractiv .
    02 Feb 2007
    Exclamation Dm 100 Are si CCCAM!!
    release new emu s/w version,
    1. In this s/w version, we fixed,
    - Add CCCAM protocol
    - Fixed 9750/10750 LNB Frequency
    - Add channel changes (Numeric/Alphabet sorting)
    - Fixed auto and manual time setting
    - Hide Server menu: Expert menu PIN code -> input pin code '0000' only shows
    tcp/ip
    setting, input '0101' show all items, you can change PIN code, too.
    - Add Email application (Only available POP3 mail receiving, mail sending
    will be
    added later)
    - Fixed Premiere sub channels (when you change another TP, it may takes some
    seconds when you get sub channels, we will make it faster later)
    http://www.sendspace.com/file/bi88d2
    In the dm100 s/w downloader (loadercheditor.zip),
    - added COM port 'auto mode'. But before press 'auto' button to look for com
    port automatically, you have to wait around 20sec until dm100 booting
    finished. If not, Automatic com port will not work.
    http://www.sendspace.com/file/33kwp2
    Asa cum se vede CCCAM e emu numai pt Dreambox receptoare si povestea ca CCCAM suporta numai receptoare cu enigma e o minciuna mare.Team de CCCAM posibil e finantat sub masa de la DM....
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    01 Apr 2007
    Default Re: Dm 100 Are si CCCAM!!
    Pai nu e minciuna , enigma1 pe IpBox cu STB02500 ruleaza linistit CCCam si aproape sigur nu va rula niciodata pe procesoare STi7xxx indiferent ce enigma vor rula ( daca nu scoate si Dreammultimedia un receiver cu acest chip ) ; TripleDragon nu are enigma si nu poate CCCam.
    Acum DM100 este mai bun decit o clona ( Blindscan si mai important USB2.0 ) si daca DM600 nu ar avea suficiente resurse ( flash si ram la discretie & programe suficiente si mature ) l-ar ingropa si pe el .
    Adio IpBox 250 / 350 si ItGate TGS 220 .
    Adio Globo/Opticum / Echolite/Echosmart / Noname .
    Astept nerabdatoe exclusivitatile decodarii cu emu ( stiti voi , AU pe pornaciuni facute de TimeBomb pe DM500 )
    02 Feb 2007
    CCCAM nu stiu citi timp o sa rezista cu politica asta deja mbox vine cu viteza de lumina!!!Si poate au suprinze ei de la cccam neplacute.Deja a scos mbox versiuna pt kathrein,ipbox,dreambox (la toate modele) pt windows (cccam merge la pc numai cu linux)acuma pregateste si pt tripledragon si pt anumite router de gen linkys.Si pt viitor nu exclude posibilitate de conectiune cu cccam...Ramune sa vedem...Dar pina acuma au facut ce au promis....
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Dm 100 Nou firmware V0126
    Dream 100 - Firmware V0126
    In this version,
    - CCCAM works perfect (priolist will be added later)
    - Premiere sub channels works good.
    Notice:
    - ‘dm100 s/w downloader’ doesn’t support WINDOWS VISTA at the moment,
    we will add it later.
    - Nemesis OSD will be released next week, you can enjoy 3D OSD or
    Nemesis OSD upon your taste!
    DM100S_V0126.rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default How to upload firmware file to Dm100
    How to upload Firmware file to DM100
    This "how to" assumes you have already installed the UART USB COM driver and the LoaderChEditor.exe
    If you haven't installed the above then check out the following threads for files and instructions.
    OK, here goes, I've attached some pictures of the LoaderChEditor process below to help newbies ;-)
    1. Connect USB A-B lead from PC to DM100 and connect power lead to DM100.
    2. Load the 'LoaderChEditor.exe'
    3. Click on 'Tools' --> 'COM Settings' Select the COM port number the UART Serial Port driver is configured to.
    4. Click on 'Conn' Button' to connect to DM100
    5. Click on 'Up' Button to upload new firmware.
    6. An Open File box will open, from the file type drop down box select "BIN File .BIN"
    7. Select the folder that holds your "DM100_Vxxx_firmware.bin" file, click on the "DM100_Vxxx_firmware.bin" file and click 'Open'
    You will now see a box appear that displays the following message, "Reset your STB'
    Remove the power lead from the DM100 then reconnect the power lead to the DM100.
    You will see another message appear, "Writing to the flash, please do not disconnect"
    There are 2 stages to the flash process, so wait for stage 1/2 to complete then stage 2/2 to complete.
    Don't worry if stage 2 hangs for 30 seconds before the progress bar starts to move, this is normal.
    Once the file has been loaded sucessfully you'll get another message box appear to say, "Complete"
    Press OK to close the message box.
    8. Now click on the 'D-Con' button to disconnect the DM100 from the LoaderChEditor application.
    9. Power off the receiver by disconnecting the power lead from the back to reboot.
    10. Switch on DM100 and select 'Factory Reset' from the DM100 on screen menu.
    Finished.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Re: How to upload firmware file to Dm100
    DM100 - Loader & Channel Editor v. 2.0
    Universal Loader und Setting Editor fur das Dreambox 100
    Ermoglicht das flashen jetzige und zukunftige Image auf die Dream 100 (*.bin), sowie das sortieren sowie hochladen von Programe und Frequenzliste in satcodx (*.sdx) oder lyngsat (*.dat) format.
    Attached Files Attached Files
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default DM100 Version v0127
    DM100 Version v0127
    Here we release new DM100 S/W,
    In this version,
    - Multi SAT SCAN by diseqc is OK..
    - Channel list editing with CCCAM setting by SBS is OK.
    - CCCAM Key editor by web server will be released in next version.
    You have to use new editor Ver2.3,
    1. You have to download V0127, by editor Ver2.3,
    2. Factory reset,
    3. Scan Live channels and download channel lists to PC
    4. Edit channel list.
    5. Upload edited channel list to DM100 and check CCCAM setting.
    Notice.
    1. Must run editor 'Ver2.3 to download upload s/w.
    2. After downloading V0127 firmware, you must run 'factory reset'.
    3. Must scan 'live channels' and download and edit it by editor Ver2.3.
    http://rapidshare.com/files/15945539...7_20081030.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
