Results 1 to 15 of 17
Thread: Versiuni Old Mbox
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Versiuni Old Mbox
    0.4 BETA build 0015
    -Added code for gbox protocol over TCP (TCP<->UDP / UDP<->TCP / TCP<->TCP). Read README.cwshare.txt.
    -Few changes in code
    http://www.upload-drive.com/3188/mbox_all_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    O zi frumoasa! Snow's Avatar
    05 Jan 2007
    Default Re: Mbox pentru ipbox 900&9000
    0.4 BETA build 0016
    -NOTICE: gbox support has been broken in this build, so dont try to connect to gbox/(old mbox) network, ain't gona work !!!!
    -Remove mapping for N3 and some Conax providers.
    -Fix problem with local card(s) priority( I hope ).
    -Fix PMT parsing code, not showing some crypto systems.
    NOTE: THIS BUILD IS HIGHLY EXPERIMENTAL!!
    Attached Files Attached Files
    05 Jan 2007
    0.4 BETA build 0017
    -NOTICE: gbox support still broken !!!
    -Fix few problems with new hello msgs.
    -Added detection if peer goes offline but didnt send offline hello msg (mbox crashed or mbox kill-ed).
    -Changed code for ECM filter(s).
    02 Feb 2007
    Default MBOX 0.4 built 0018
    0.4 BETA build 0018
    -Added W option in add.data file to request current dcw caches from one peer.If there is some dcw caches from that peer, new dcw_cache.info file will be created in tmp path.
    -Fixed few problems with new hello msgs again ).
    -Better handling ECM filters
    http://www.upload-drive.com/3644/mbox_all_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    05 Jan 2007
    Default Re: Versiuni Mbox
    0.4 BETA build 0019
    -Fix not showing online some peers.
    02 Feb 2007
    Default Mbox 0.4 Pre BETA built 0020
    File Name: mbox 0.4 PRE BETA build 0020
    File Submitter: mower
    File Submitted: 2 Feb 2009
    File Category: MBOX EMU
    -TCP peers/connection (TCP0/TCP1 in cwshare.cfg) now works only with mbox peers!
    -Mbox peers will have 1.00 as version number.
    -Mbox peers now must be in G line in cwshare.cfg,D line stay for old gboxx peers.
    -Added R option in mbox.cfg.
    -Added J option in mbox.cfg. You can change J option with add.data at any time.
    -Added A option in mbox.cfg , needed for QBoxHD receivers.
    -Added back gboxx connection/protocol.Gboxx peers cant connect to mbox peers and vice versa!!!!
    -Mbox now starts as deamon(background process).
    -Fixed HD channels.
    -Fixed problem with duplicate boxids, now mbox keep only boxid that has lower distance.
    -Added support for AzBOX receivers(binary-> mbox_module).Dont expect mbox to work as should, because current API for AzboX receivers has restrictions regarding ECM "pids" streaming.
    http://www.upload-drive.com/7709/mbox_all_rar
    Last edited by zmeura; 02-02-09 at 21:47. Reason: L-am pus si pe forum,am avut probleme cu upload-drive.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Membru de onoare
    08 Apr 2007
    0.4 PRE BETA build 0021 versiunea 5
    -Fix problem connecting to old mbox 016-019 versions.
    -Fix problem with stack
    -Fix problem with sending good ECM message to mbox ver. 0016-0019.
    -Added H option in mbox.cfg for mapping provids.
    -Few changes in code for local card priority, H option in cwshare.cfg.Now local card priority should work ok.
    -Added code to check if same ECM is allready in ECM buffer for local card decoding over newcs.
    ATENTIE:Liniile venite din gbox si mbox versiuni sub 0015 inclusiv sunt linii D iar cele venite din mbox 016 sau mai nou sunt linii G,avand aceeasi configuratie in stil "old gbox".
    02 Feb 2007
    Default Mbox 0.4 PRE BETA build 0021 REUPLOADED 6-th time
    mbox 0.4 PRE BETA build 0021 REUPLOADED 6-th time
    -Fix problem not setting CA pids after channel change for devices that use dvb api.Screen stay black.
    -Fix problem sometimes mbox start hitting cached CW for same ECM all the time.Now it should be okey.
    http://www.upload-drive.com/7796/mbox_all_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default Mbox 0.4 PRE BETA build 0021 REUPLOADED 7-th time
    -Fix problem black screen if first DCW is from cache for devices that use dvb api.
    http://www.upload-drive.com/7804/mbox_all_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    Membru de onoare
    08 Apr 2007
    0.4 PRE BETA build 0021 8-th time
    -Fix problem with black screen if using local card for decoding over newcs for devices that use dvb api.
    Default 0.4 BETA build 0022
    0.4 BETA build 0022
    -Added mbox.prio file for adding priority system selection.Put the file in "K line-mbox.cfg" path directory.If no dcw arrived after several ECM send, mbox will reread PMT without using priority list.
    Membru de onoare
    08 Apr 2007
    Mbox 0.4 BETA build 0022 3 REUPLOAD
    -Fix bug resharing cards from gboxx and mbox peers to each other.
    -Few small changes in code.
    -Fix problem mbox hangs after hello message.
    -Fix problem repetition of CaID 0x1702 ...found CW in cache on Premier channels.
    -Changed priority code ,so now you can use P line with or without sid pid.P line with sid pid has priority over P line without sid pid.
    -Changed how much ecm/sid pids can be loaded from port.list file, from 150 to 500 pids.
    02 Feb 2007
    Default mbox 0.4 BETA build 0023 1-st REUPLOAD
    0.4 BETA build 0023
    -Fix problem with returning wrong boxid in (cached) DCW message.
    -Few changes in cache code.
    -Few changes in code for cards reshare.
    -Added support for SSSP protocol, S line in mbox.cfg, tested only on Windows OS, on Linux OS still doesnt work!!.
    -Added support for triple dragon receiver(set D on 5 in mbox.cfg).
    -Few changes in code for Qbox HD receiver(set D on 6 and A on 1 in mbox.cfg).
    -Information in stat.info file is just for mbox peers!!.
    -Added mapping , from 1815 to 1801 in H line (mbox.cfg).
    http://www.upload-drive.com/8624/mbox_all_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default mbox 0.4 BETA build 0023 2-nd REUPLOAD
    0.4 BETA build 0023
    -Few changes in sssp code, affect just mbox.exe file.
    http://www.upload-drive.com/8625/mbox_all_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
    02 Feb 2007
    Default mbox 0.4 BETA build 0023 3 REUPLOAD
    0.4 BETA build 0023
    -Fix problem mapping 1815 to 1801, add mapping from 1822 to 1801.
    -Few changes.
    http://www.upload-drive.com/8665/mbox_all_rar
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
