Imagine testata,nu contine time-bomb!
Dislikes: 0
pm
Gemini v4.6:
Technical Infos:
* Enigma of: 19.12.2008
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt V1.104
* CIFS 1.44
Remotecontrol:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Addons:
* own Addon-Server via Internet
* adding additional functions via internet from the Gemini-Server and install them automaticly
* Personal Addon-Server can be used (configuration via /var/etc/useraddon.xml)
* Create your own Satellites.xml, which only contains the Satellites you realy need
Camd:
* Different Camd´s can be linked to channels/provider (Autocam)
* Changeing the name and settings via own menu.
* Creation of a 2nd socket (/tmp/cam1.socket)
Daemon / Server / Clients:
* Automatic test wehter the box is connected with the internet or not (Well be shown in the infobar)
* Dropbear (SSH) now switchable (DM500 - DM7000: Standard->off)
* added editor to configure the cron-daemon
* Little Apache (HTTP-Server based on HTTPD)
* Upnp Client and Server (for DM500/56x0 must be installed from Gemini-Server as addon)
* Inadyn (Daemon for different DYNDNS-Services)
* Settings for syslogd
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found in the BP)
* NFS-Server (based on the NFS-Kernel-Modules, nor for DM500, DM500+ and DM56xx)
Infobar / OSD / Skin / Background-Pictures:
* Position of the Infobar can be changed without editing the skin files
* Provider, Frequencies, Symbolrate and FEC can be displayed in the Infobar (If the Skins matches this function)
* Display of EMM, ECM or "Expertinfos" are switchable
* Picon (displaying the Channel-Logo)
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar)
* Background picture can be turned off (Plasma - Fix)
* Backgroundpictures (Radio- and File Mode) can be used as Screensaver.
* Changing Bootlogo via menu ( 7020 only)
* Backgroundpictures and Bootlogos can be created, testet and used direct on the Box (out of JPG, BMP, GIF or PNG)
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in Expert Menu -> Network)
* Moved Gemini events (Ripper, Calendar, email-Checker) from BluePanel Menu into the infobar (eLabel-Name = geminievent)
Files / Devices
* Support for CDROM/DVD no matter using IDE or USB
* Random function for all kind of soundfiles
* Backup function
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* support for the bigger remotecontrol on 500 and 500+ (normaly shipped with 70XX/600pvr - activate on BP->Extras/Settings)
* Support for FLAC, OGG/Vorbis and WAV (please install codecs in the BP)
* Functions for SWAP (virtual memory). Create, delete, size and location.
* Device-Manager for HDD / DVD / CF / USB
* Drivers for USB-Cardreaders are now included in the Image but are not loaded!
EPG
* additional functions (e.g. dishnetwork, cache, location)
* search all channels for an event or an own string. Timers can be added immediatly (Press "Menu" in the epg or use use BP -> extras -> EPG-Refresh)
* Infos of the recorded movies can be shown without starting the movie
* refresh EPG using the enigma-timer (BP -> extras - EPG-Refresh)
* autosave for EPG-cache ( BP -> Extras/Settings -> EPG-Settings)
* Duration of current event in the programm overview ( Menu -> Info -> EPG)
* general information about the EPG Data (BP -> Info-> EPG-Settings)
* a time period for the EPG Data can now be defined (BP -> Extras/Settings -> EPG-Settings)
Extras:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s) (for DM500/56x0 must be installed from Gemini-Server)
* RSS und Weather Plugin (for DM500/56x0/7000 must be installed from Gemini-Server)
* System Info: Many extra box infos like HDD temprature, stream-rates (>=7000) or kernel-, memory- and prozessinfos.
* Own scripts can be started via Blue Panel
* Changing the recording parameters (extra before- and after- recording time, storage location and recover-function for your records)
* change the settings for recording (before Time, after-recording time,, location and recover-function)
* Create your own satellites.xml including only the satellites you really need.
* Quick-Button-Menu: Many extra features for the yellow button (e.g permanent clock in OSD, freeze Image, audio selection)
* alarm-clock with volume offset playing own WAV-Files
* Calendar for iCalendar format + reminder ( Supported by MAC, KDE, Thunderbird, Goole calander, Rainlendar...). Standard folder is /var/etc/ical (for DM500/56x0 must be installed from Gemini-Server)
* Support for DreamDVD no matter wether a DVD-Drive is available or not
* New screenshot routines (have a look at the Webif)
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD (for DM500/56x0/7000 must be installed from Gemini-Server)
* disable the TV - output while taking a recording, streaming a movie and manually (usefull for boxes with very low lan-speed)
* update system time via transponder or internet ( Protocol RFC868 )
* eMail-Checker extended with SSL support (Overview of your POP3 or IMAP accounts)
* create password using the BP (BP -> Extras -> Pwassword)
* rotate al kind of pictures. Also automatic rotation using EXIF (must be activeted using the menu)
* Re-Zapp, zapps after X-minutes to the actual Channel (BP -> Re-Zapp)
* Displays, wether the box is an original one or not (using MAC adress, BP -> System -> Dreambox -> Manufacturer)
* the Jukebox, Please install as addon.
Recordings:
* records into different folders ( the settings have to be done in the Timer-Menu)
* LED´s are flashing during record (Boxes without display). Must be set in BP -> Extra -> Record
* import of recorded movies every time you enter the Video-Menu or only once when the Box ist starting (BP -> Extras -> Record)
* Records can now be done in the new Eniga2 format (*meta files) or as usal as "recordings.epl" (BP -> Extras -> Record)
New:
* Webcam Viewer for viewing images from the Internet, configureable via XML config (only Still, no interval as we have at E2)
* Now you can perform a network-settings test (new construction + wizard)
Fix + update:
* Dreamnetcast
* RSS-Reader
* Jukebox
* Changed OSD & Video grabbing
* have a look in the CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
http://127.0.0.1/cgi-bin/setKey?typ=...est&val=blabla
http://127.0.0.1/cgi-bin/getKey?typ=...tedvb/int-test
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background. We assume no liability for direct or indirect damage.
DOWNLOAND!!
easysurf.ro_GP460_DM500_drhg_NOBOMB.zip - 4.8 Mb
r12
Cum poti sa-ti dai seama ca nu contine time-bomb?Dar nemesis 4.4 contine time-bomb?
Tu nu poti vedea asta? sau daca o vezi nu sti a citi?
Doar imaginile geminii au momentan time-bomb!
Bai da varianta asta nu poate face pok de la bomba?
Eu am pus-o de 4-5 zile si nu a crapat nimica inca...spre bucuria mea
mai astept?
Imi place cum merge si e fara bug-uri, sau nu am remarcat ica. Subtitrarea e ok.
Am tot citit de GP4.60 ca pusca in clone, dar nu de varianta pusa aici (GP 4.6 no timebomb)
Am bomba pe clona ...dar am mac schimbat . Oare e alta bomba undeva ?
O fi si alte bombe ... incendiare 100 %.
Doar ca clonele (DM-urile facute in afara programului) functioneaza inca fara probleme cu 4.60 si MAC modificat.
Fost membru al acestui forum
si cand ma gandesc ca, cu cateva luni inainte anumiti useri se bateau cu pumnul in piept, ca in veci nu o sa mai puna gp pe clona lor si acum ii vad cum "probeaza" ma apuca rasul :=))))))))))
Am pus si eu imaginea asta pe cateva clone, unica chestie care nu imi place este barcuta care mi-o arata la inceput, in rest totul ok
La mine cu skin Nemesis Glassline prezinta ceva bug-uri, adica lipsesc unele caractere in screen-ul care apare la "info". In rest ok.
Dar pot sa va spun ca acum merg cu cea originala pe o clona cu mac original si nu s-a intamplat nimic inca.
La cine anume te referi ? Sa radem si noi
dm500 daca are mac 000934xxxxxx merge stas cu gp cu bomba.
ce am auzit referitor la gp 460 e ca ocupa cam mult spatiu... nu stiu sa ma pronunt ca n-am probat inca, dar chestia asta am auzit-o din mai multe parti.
Pai si cine a pus geminii original? tu nu ai observat ca este modificat si skinul de boot ? iti apare dream-Gaza-Team? si nu geminii? este un geminii modificat binisor pentru clone asa ca te cam apuca rasul degeaba amice,eu nu vam mai recomandat nici un geminii original de la 420 in sus ci doar cele modificat soft si fara team-bomb,ia pune tu un original si pune si versiunea asta no time-bomb,difera 2 skinuri in no time bomb si nu are time bomb fata de cea originala!
Eu recunosc ca am spus ca nu bag GP . Dar cum sa nu bag daca am modificat MAC-ul si nu imi este teama sa testez ?
Va este teama sa testati ... stati cumintei pe alte imagini si nu aveti dureri de cap . Dar... nici satisfactia unei reusite nu o sa o aveti.
GP 46 e mai rapida si claritate super , restul descoperiti singuri.
Bafta.![]()
dar tu la care te referi ..aia cu time bomb sau fara time bomb?
La cei ce au clone fara mac modificat. Bombe sigur o sa mai apara.
